Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MAP Sensor
Thread: MAP Sensor
Old 05-14-2003, 10:15 AM
NAIRB's Avatar
NAIRB NAIRB is offline Moderator
If you have multiple codes, you must isolate variables to pinpoint the problem. Do not guess by buying a bunch of parts. Scan the car, and write down the codes that are present. If some of the codes are historical codes, I would clear them by unhooking the battery cable for a couple of minutes, then let the vehicle run for a while to get the hard (current) codes from the ecm.
