Map sensor - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2005, 05:22 PM
Map sensor
Im having trouble locating the map sensor on 86 Pontiac Firebird Trans Am 5.0 TPI. Could somebody explain where this is located. Thank you for your help.
Old 05-15-2005, 06:26 PM
edge's Avatar
Time is short, are you ready?
That's because the TPI did not start using MAP sensors (Speed-Density) until 1990. A stock 86' TPI is a MAF system. Ed www.edgesz28.com
sensor light keeps coming on wiseguy50 Engine 6 01-14-2006 07:21 PM
Emissions HELP cutsupreme Engine 33 12-27-2003 09:22 AM
O2 sensor crshrmn3 Engine 2 09-01-2003 02:12 AM
MAP Sensor chevracing Engine 9 05-19-2003 05:43 AM
convert from map sensor to mass air flow cgreene Engine 2 05-10-2003 08:29 PM
