MAP sensor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2005, 09:27 PM
aceofspades49c's Avatar
Cobra killa
MAP sensor
hi
i have a 1984 camaro z28 and i have done some mods to the 305 h.o. engine , demon carb , mild cam , headers, intake,
it runs good, but i found some thing out. with the MAP sensor on the firewall the vacuum hose is missing and i cant seem to find out where the hose comes from ,
can anyone tell me where the MAP sensor vacuum hose goes to. to read the vacuum signal??
any help would be great
thanks alot
Old 10-22-2005, 04:53 PM
97Z28's Avatar
NTI Grad.
the MAP sensor should be plumbed directly into the intake manifold
Old 10-23-2005, 08:02 AM
1981monte's Avatar
If you are running a Demon carb. than the computer system is not controlling the air fuel. So the Map sensor being reconnected won't matter. What I did with my Monte was remove all the computer related wiring and drooped a HEI distributer in it. Just may have to worry about emission laws in your area.
My car will be 25 years old when I take out next spring, exempt from emission's in NY.
Old 10-23-2005, 08:05 AM
1981monte's Avatar
Dam should of used spell check..LOL.
Map sensor HerTA Engine 1 05-15-2005 06:26 PM
Emissions HELP cutsupreme Engine 33 12-27-2003 09:22 AM
O2 sensor crshrmn3 Engine 2 09-01-2003 02:12 AM
MAP Sensor chevracing Engine 9 05-19-2003 05:43 AM
convert from map sensor to mass air flow cgreene Engine 2 05-10-2003 08:29 PM
