Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MAP sensor location?
Old 02-19-2006, 10:29 PM
Rick WI Rick WI is offline
Off the top of my head I would think in the interest of achieving a solid map signal I would tap a hose barb into each plenum under the throttle body and Y the two hoses into one then into the map sensor. I'd locate each hose barb right under the throttle bodies.
