maradyne electric fan control install - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2011, 11:17 AM
I bought a maradyne electric fan with an adjustable controller mfa100.Has anyone installed one of these,any hints before I start ,the instructions are a little vague..............thanks Bruce
Old 01-12-2011, 02:25 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The attached schematic diagram shows the wiring.
The controllers I have used measure the temperature of the coolant. It appears that the Maradyne unit has a sensor that measures the air temperature.
I don't think that would work as good.
vicrod
Old 01-14-2011, 12:25 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Not savvy on that exact unit, typically the fan voltage will be switched through a relay. The relay is activated via the water temp at the head or intake manifold. The unit may contain the relay as one device with remote sensor located in a well. Make sure to fuse the elec fan motor as close as possible to the 12 vdc source, use 10-12 gage wire for all the power side wiring typically at 25-30 amps fused but check for correct amp rating.
If this thing is switching based on air temp get rid of it.
TJ
Electric Cooling Fan control setup 76_TA Engine 11 09-01-2010 07:13 PM
Electric cooling fan control yragat Electrical 5 03-07-2008 03:15 PM
Electric Fan Control Questions Houston54 Engine 2 06-12-2007 09:19 PM
install electric cruise control EGOP8 Electrical 2 01-10-2006 04:37 AM
cruise control install verohd General Rodding Tech 6 06-10-2005 06:47 AM
