March pulleys - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2002, 07:00 PM
New Member
Post March pulleys
Just got the 396 in the chevelle ceramacoated headers and all now on to the accesories Has anyone ever installed a set of march pulleys?
if so did you have any problems? were they easy to fix so on an such
the set i have is for the multi-groove belts with the alt on the pasenger side with no air. it uses the long water pump... the reason i'm asking is because i cant mock the stuff up yet
because the local speed shop hasnt got my victor pump in yet
Old 02-11-2002, 10:37 PM
Post
March makes good stuff. As long as the pulleys you have are made for that engine they will go on like factory pulleys. ROY
Old 02-12-2002, 08:19 PM
New Member
Post
the pulleys are made to fit a big block with the long water pump including power steering and a passenger side alt
i am kinda curious about that long pump fitting in the chevelle though
buy the way roy i took your advice and kept the T.H.350 in the car
[ February 12, 2002: Message edited by: cheapo48chev ]</p>
Old 03-12-2002, 06:49 PM
Post
I purchased a set of march pulleys for my chev. 350 ho engine. That look great and bolt right up no problems
[ March 12, 2002: Message edited by: tes0752 ]</p>
Old 03-12-2002, 08:13 PM
New Member
Post
well i have them on the engine now the only problem i encounterd was that the bolt that goes through the lower alt was for a smallblock so i had to creat my own spacer and bolt combo but other that that they work perfectly
