Marge's radio died. :( Any ideas? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-28-2014, 06:51 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by boothboy View Post
Blasphemy!! Tech old Man you just don't understand. Old tube type radio's have a entirely different sound. You can't make toast over a modern radio but you can over the warm glow of a old tube type radio. You can't read a map by the light of a modern radio but you can from the light emitted from a tube type radio. Stuck in a ice storm, try defrosting your fingers with a modern radio . Those chips and gizmo's won't help you but salvation will come from grasping a 12BGE or the like. If Brian were to abandon that old Motorola in Marge, why She might have to change her name to Tiffany or Ashley or some such.
No Brian, tap that vibrator or push those tubes back in their sockets. There's life still in the old girls innereds yet!
BB
Vacuum Tube Car Radio Motorola 300 - YouTube
Transistor the sound is not the same as the old tube type
remember Tommy James ,Tommy Roe and the Ventures Wipe Out,the just don't sound the same now, My brother had a old 50 ford flat head 6 ,But it had a good radio that is all that mattered back then.
  #17 (permalink)
Old 01-28-2014, 06:57 PM
Oooooo, Tommy Roe and the Ventures Wipe Out and you reach under the dash click it over to Reverb!
BB
  #18 (permalink)
Old 01-28-2014, 07:06 PM
Built Not Bought
BB
Later after I was old enough to drive my Dad bought me a 65 GTO with the reverb and a 45 record changer ,thought that was Cooool,
  #19 (permalink)
Old 01-28-2014, 07:20 PM
Last journal entry: New Rev wheels and BFG KDW II tires
Originally Posted by Too Many Projects View Post
Nice,
I have an old Marantz in my shop and the volume switch is going out. One speaker cuts out when I dial it up for a good tune and I have to "play" with it to get the speaker back. Any idea where I might get a replacement switch ?
Sounds like it just needs to be cleaned. Pretty typical of vintage stuff after all these years the contacts get dirty. Deoxit D5 is very good stuff.
Be careful of some contact cleaners as they can be harmful to plastics and some don't have a lubricant. They might clean it but won't provide the lubrication the contacts need.
Amazon.com: Hosa Cable D5S6 Deoxit Contact Cleaner Spray: Musical Instruments Amazon.com: Hosa Cable D5S6 Deoxit Contact Cleaner Spray: Musical Instruments
I've got a Marantz 2385 too. Wish I had the optional wood cabinet for her.
  #20 (permalink)
Old 01-28-2014, 08:16 PM
Wiki Edits: 31
Originally Posted by killeratrod View Post
yes sir ,and i will take it one step further . I buy, sell & trade Vinyl records & turntables , Mics. Hell anything music. side thing!!
I have a USB turntable sitting atop my stereo system. Not lucky enough to have a tube amp. I have an Onkyo A-7040 that was made in 1981, tuner is a Pioneer TX-6500II ( 1977 vintage ) and my CD changer is a Marantz CC-52 made in 1991.. All of it works great togther, and I can record and split the vinyl tracks into MP3's if I choose.. My vinyl collection expands fairly rapidly when the local thrift stores get new vinyl in.. $.50-$1 per record and many are in VGC++ condition.
  #21 (permalink)
Old 01-28-2014, 08:28 PM
Semper Gumby
Wiki Edits: 2
At one point I had a pair of bridged David Haffler DH250's - one per channel, (running 500 W per channel) driven off a Soundcraftsman Pre-amp/equalizer, pushing into Cambridge Audio Towers. Used a Heath FM tuner and a McKay-Dymek AM tuner. Still have the C/A towers, but using a 1970's Sony receiver to drive them now
  #22 (permalink)
Old 01-28-2014, 09:40 PM
evolvo's Avatar
Martin,
I just happen to have a "Sams Photofact Auto Radio series" repair book from April 1969. My memory is a little dim, what kind of car is "Marge"? See if you can find a make or model # on the radio and I'll tell you if this book covers it. If it does I'll send it to you as a late Xmas gift!
  #23 (permalink)
Old 01-28-2014, 09:42 PM
I'll check out to see the brand. Thanks, and thanks everyone for the tips. I am thinking the cleaning may help the one in the Gran Sport too, it's pot is all goofed up and when you turn the volume it cracks big time.
  #24 (permalink)
Old 01-28-2014, 09:43 PM
Semper Gumby
Wiki Edits: 2
Brian: There are about a zillion Rambler radio parts on E-bay. Also found radio service manuals for Rambler Radios, too.
Also on the internet there are many many places that specialize in fixing old automotive radios, so if you want to keep Marge all original, there are many options
  #25 (permalink)
Old 01-28-2014, 10:54 PM
I may have time this weekend to pull it out. I think I have the fake knobs to put in it's place so it doesn't look naked.
I have planned on adding a stereo to her but I will want the original radio in the dash.
  #26 (permalink)
Old 01-29-2014, 07:27 AM
Motorola manufactured your radio Brian. And Dave is right. Ebay's full of them!
BB
  #27 (permalink)
Old 01-29-2014, 09:25 AM
put up or shut up
I got a solution...
  #28 (permalink)
Old 01-30-2014, 03:55 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
Yes, that looks just like mine...
So do I take the volume control out to clean it or can it be blown out with the case removed ?
  #29 (permalink)
Old 01-30-2014, 06:41 PM
You don't have to take it out. Try removing the bottom cover and you should be able to see it. There are usually small holes in the "pots" that you can spray the cleaner into. When you do that, move the control back and forth several times. Repeat this process a couple times.
Put the cover back on and let it dry out. It should be good after an hour or so. Don't turn it on until you let it dry out and then test it out.
Sometimes it will take a few cleanings before all the scratchiness is gone. If you can't get it to clean up the pot may be worn out. Then you will have to scour Ebay for someone that is parting one out.
It depends on how popular the model is how much luck you will have if you need to find another one. Usually they aren't all that difficult to solder a replacement in if you need to do so.
The Following User Says Thank You to 64SS327 For This Useful Post:
MARTINSR (01-30-2014)
Poll: Radio or NO Radio Centerline Hotrodders' Lounge 47 12-12-2010 08:56 AM
radio surround plate ideas gothrod87 Interior 11 04-26-2007 03:53 PM
Large Marge has left the Building TooMany2count Hotrodders' Lounge 5 04-02-2007 09:33 AM
more on Large Marge TooMany2count Hotrodders' Lounge 3 02-01-2007 01:26 PM
Large Marge's Heart Beats for the 1st time TooMany2count Hotrodders' Lounge 9 12-30-2006 10:35 PM
