Marine 350 with LT-1 Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2002, 11:38 AM
Post Marine 350 with LT-1 Heads
I have a Chevy 350 (91) in a boat. I was considering replacing the iron heads with the newer LT-1 aluminum heads. Anyone foresee any problems with this combo?. Cooling is a closed circuit type.
Old 12-20-2002, 12:20 PM
DoubleVision's Avatar
Post
as far as I know, the LT1 heads are for reverse flow cooling blocks and will not interchange. the water ports in the heads are redirected and do not match the old style cooling passeges.
Old 12-20-2002, 04:18 PM
BOBCRMAN@aol.com's Avatar
Post
you will not like aluminum heads on a boat motor, boats have a hard time building heat with iron heads, with aluminum heads you would never get to a good operating temp, that is not good on the engine also you have to watch for corrosion problems
Old 12-21-2002, 03:52 AM
Post
Thanks DV, I wasn't aware that the cooling holes were different.
Old 12-21-2002, 04:10 PM
Post
Why not just put a set of Vortec heads on it? They basically took all that was good from the cast iron LT-1 heads (the better flowing of the two) and put it to use on a set of standard coolant flow SBC heads. Plus they are pretty damn cheap brand new.
Old 12-21-2002, 07:23 PM
Post
Hi KV, I thought about Vortec heads however, I was hoping for light weight aluminum heads. Ebay's got LT1 heads for around $200. If I had an LT1 block could I fit it with regular 350 crank and pistons?
Old 12-21-2002, 08:20 PM
Post
If you are dead set on aluminum heads, it would probably be cheaper in the long run to get an aftermarket set. Think about it. You are talking about completely building an engine around a set of heads. By the time it is all said and done with the LT1 you could have had a decent set of aftermarket aluminum heads. Take a look around out there. They aren't as expensive as you might think. Good Luck!
