marine 383 hi torque - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-30-2012, 02:10 PM
more on 383 stroker
like i said the boat is not for racing but should be able to pull skiers easily and have some fun it look"s like the cam is very important any part numbers that i should look at? exhaust's are wet as i understand (big bulky and don't look like they are in very good condition so for heads can i use EDL e street with performer int and 600 marine carb? (will use 383 stroker kit and ballance the assembly ) hopefully you can make sense of all i write. thanks its allmost midnite here in Kimberley South Africa!!
  #17 (permalink)
Old 11-30-2012, 02:32 PM
vinniekq2's Avatar
yes you can use e street heads and 600 carb.If you dont own them then I dont see why you would buy them? The 3.8 stroke might be a good idea.
another option to bring the rpm down lower and increase the torque sooner
4.03 bore X 3.875 stroke= 396,with same parts I mentioned before or sub street master intake, small roller hydraulic and 500 pounds torque should happen. In a ski boat I would think pulling 6 one ski skiers as easy.
  #18 (permalink)
Old 11-30-2012, 03:45 PM
hcompton's Avatar
Old & Furious
Originally Posted by 1Gary View Post
Here is some of Richard's work with me on 383 torquer:
Custom cam 206/214, 106/113/109.5, 0.420"/0.420, (-3)(29)(40)(-6) installed straight up.
Streetmaster intake manifold (1st design).
http://cgi.ebay.com/ebaymotors/Edelb...Q5fAccessories
RPM HP TQ
1000 88 461
1500 149 521
2000 204 535
2500 247 520
3000 289 506
3500 319 478
4000 346 455
4500 357 417
5000 348 366
5500 319 305
Peak BMEP 210.8 @2000. This is some serious cylinder pressure, so a very tight squish (I would be thinkin' 0.035" to 0.040" with a D-cup piston) would be mandatory to prevent detonation on pump gas.
Do think it would work well in a marine application.
That cant be a real dyno reading. Hp and tq are way off. If your making 500ft of tq then you would be making at least close to that in hp. Not less than half with a much wider power band. Cam also does not seem to have a VE in the 2k rpm range. Is that engine sim or something. I must be missing something. That looks too good to be true.
  #19 (permalink)
Old 11-30-2012, 07:15 PM
Richiehd's Avatar
JS-70
[QUOTE=gerry rautenbach;1617522]like i said the boat is not for racing but should be able to pull skiers easily and have some fun it look"s like the cam is very important any part numbers that i should look at? exhaust's are wet as i understand (big bulky and don't look like they are in very good condition QUOTE]
Jerry,Get yourself a marine performance cam.You should stay under 280 degrees duration. When you call the tech line for help make sure and ask them about water reversion, if the guy says "What?" hang up and move on!! Then contact Jones Cam Design in North Carolina
If you are to take full advantage of all that horsepower you are going to have to step on the exhaust. Glenwood makes an excellent exhaust log and elbows that will not be that of a header but much better than cast iron manifolds. A little pricey but worth the investment and will give you years of service, plus they look great! Glenwood located in California USA
  #20 (permalink)
Old 12-01-2012, 02:20 AM
water reversion
could you explain what water reversion is (never heard of it before)
  #21 (permalink)
Old 12-01-2012, 05:21 AM
Richiehd's Avatar
JS-70
If you get too much cam overlap and duration, water will get sucked into the exhaust on the intake stroke. You might also find the motor would start dry but when it is in the water, would not start because the exhaust pipe is filled with water. A good cam grinder understands this if he has done work on marine engines before. Usually under 280 degrees duration. I called one of the big cam manufacturers one time and had to explain this to the guy on the tech line. Thats when some one on this site turned me on to Jones Cam Design who has ground cams for marine engines before. I gave him my specs and he had 2 choices for my engine. I put in a solid lifter cam that pulls well from 3500 right up through 7200 rpm.
  #22 (permalink)
Old 12-01-2012, 05:47 AM
more on 383 stroker
gee thanks a lot sorry that i sounded a bit stupid but as i said boat motors is new to me so i think i will go for a hydraulic roller e street heads performer int that should be a good combo from idle to lets say max of 4500-5000 rpm do you think i am on the right track?
  #23 (permalink)
Old 12-01-2012, 12:34 PM
Richiehd's Avatar
JS-70
Nobody stupid here, everyone has questions. Yes you are on the right track. You see now why a marine cam is different? What did you decide about the exhaust?
  #24 (permalink)
Old 12-02-2012, 02:58 AM
exhaust
now you are really going to think i'm stupid what should i use the old exh looks like it is ready for scrap metal ( by the way i sent a mail to jones cams waiting for reply) should i use something similar -aftermarket ? any part numbers i can look at ?
  #25 (permalink)
Old 12-02-2012, 04:38 AM
Richiehd's Avatar
JS-70
Here is the link to Glenwood. Maybe you might find a dealer near you that could help
Glenwood Marine Equipment
I might have decent picture somewhere, you might have to wait until Monday
Marine 383 build mtnrat Engine 25 03-31-2014 06:47 PM
383 marine stroker Gerry S Hotrodding Basics 1 11-25-2011 08:48 PM
Ignition Timing on a 383 for Marine Use crussell85 Engine 5 05-14-2011 10:11 PM
383 Marine project. QJet rejet? tommytempest Engine 3 09-05-2004 09:29 AM
Marine 383 carb issues drn Engine 5 07-06-2003 10:18 PM
