Marine Applications
Can anyone provide information on installation of marine distributors?
Huh ???????
Install same as on car engine,engine doesnt know its in a boat !!!!!!!!!
Marine Distributor
I know that boatbob2. Seeing that this is a hotrod site, I needed to see if anyone had experence in marine applications. The issue at hand is I have no spark after replacing the stock distributor that was converted to electronic with a pertronix kit for SBC motor, with a Mallory YLM624AV distributor. I connected the new distributor per the instructions that came with the distributor. I have replaced the old coil with a new one recommended for the Mallory. Whoever owned the boat prior to my getting it, converted the stock distributor and for some reason connected a wire running from the starter to the neg side of the coil. Wondering if you might have ideas what else my might need to check. Thanks for the reply.
rotation
A very common issue with distributor replacement is getting it the correct position related to the correct piston position.
Make sure the rotor is at #1 cylinder on the compression stroke. Also, on some twin screw boats one engine will rotate in reverse. The distributor is built differently because of this. You may have the wrong rotation distributor. vicrod |
| What applications can gm tbi be made to work for? | Gordo84 | Engine | 33 | 07-08-2011 07:49 AM |
| researcing blower applications | Dats4me | Engine | 18 | 05-16-2011 04:33 PM |
| what applications are 390 FE fords good for?? | 427feracer | Engine | 7 | 01-23-2008 09:49 AM |
| Q-Jet for dual quad applications?? | fearsomefairmont | Engine | 7 | 11-10-2005 07:32 PM |
| Are T.R.W. pistons used in stock sbc applications? | 85 vette | Engine | 3 | 12-18-2004 06:35 AM |
