Marine Carb Selection - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 03-06-2011, 04:20 PM
The mobile view is crap
the crank is a scat 9000 1 piece rms with 5.703" rods. The crank has the file number stamped on it from being balanced. When the engine was balanced the shop had the crank,rods,pistons,flexplate,and balancer so I am sure everything is correct otherwise it would have never passed the balance, right? The engine was in my truck for about a year and ran very smooth with no vibration at all.
  #62 (permalink)
Old 03-06-2011, 04:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You are good to go. I had thought this was an untried engine.
  #63 (permalink)
Old 03-06-2011, 04:23 PM
Well, I am still trying to figure out if the flexplate is a 350 flexplate and I can run the flywheel from the 305 on the engine?
  #64 (permalink)
Old 03-10-2011, 09:11 PM
OLNOLAN's Avatar
Flywheel
Hey C, Did you ever figure this out? I did a bit of looking around, I've got a 97 vortec 350 sitting in cold storage so I was curious about the 383 conversion. If you goggle (18)35003 you find your flexplate with the external weight. It seems your 383 is external balance if it has the scalloped flywheel and the weighted flywheel. If the 305 flywheel has the weight boss just like your flexplate I (think) you're good to go. They seem to have more ways to balance this combo. Neutral balance front of crank adding mallory to the front crank throws with neutral balance harmonic damper, mallory too expensive to do the rear, so add a weighted flywheel/flexplate. Or weighted front and rear with drilling the crank for perfect balance.
If you post this question to the pro builders, with a thread title on 383 balancing, I'm sure there is someone here that can validate it. I want to know for sure too. olnolan
  #65 (permalink)
Old 03-11-2011, 05:28 PM
Here it is Balanced 383 Rotating Assembly, Have some questions?
  #66 (permalink)
Old 03-20-2011, 02:46 PM
I have cam to the conclusion that I am going to run the 383 with the flexplate. I talked to a few different guys around my area that told me I should be fine running the flexplate.
On to the next question. I plan on running this:
383, 4.030 bore 3.75 stroke
Brodix -8pro cylinder heads http://www.brodix.com/heads/-8.php
Edlebrock Performer RPM Air Gap Intake Manifold
Stock Exhaust
Camshaft: http://www.cranecams.com/product/car...detail&p=24200
Static Compression Ratio is 10.3:1
Dynamic Compression Ratio is 8.59:1
The boat has a stock Holley 2barrel 500cfm carb. Will this be enough carb to feed this engine?
  #67 (permalink)
Old 01-31-2012, 09:54 PM
I am trying to fix some mess ups during these winter months trying to get it ready for summer. I know I have asked a few times about this but I am still looking for a cam selection and a carb choice. I think I have the cam chosen but the carb is still up in the air. I am currently running a Holley 4160 600cfm. I have been told by several people that the carb is on the very small side for a 383. I am looking at the Holley 4150 750cfm double pumper http://www.summitracing.com/parts/HLY-0-80537/ or the Edelbrock 1410 http://www.summitracing.com/parts/EDL-1410/. I'm not sure which one I want or which one is better/easier to tune.......etc.
carb selection for a chevy 355 small block pds23 Engine 3 07-21-2008 06:55 AM
Lean problems with BG Speed Demon carb Sixtyninemercury Engine 29 04-16-2008 09:02 AM
Carb Selection - Help Needed S10 Racer Engine 2 04-13-2008 10:53 PM
HELP cam, intake and carb selection? sniper4570 Engine 5 01-15-2002 09:16 PM
