Marine Flywheel (454) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2007, 07:49 AM
BT74's Avatar
I have a chance to pick up a flywheel for an externally balanced 454 for short money. The guy selling it says it is from a marine application, but that it will work in a car. He says the boat used a coupeler that bolted in place of the pressure plate, and that it should be fine for an automotive application. Anyone familiar with boat flywheels?
Old 06-12-2007, 08:28 PM
BOBCRMAN@aol.com's Avatar
Have used and sold many.. They will work on an auto/truck application if--
IF the flywheel is from a reverse rotation Marine app. You will need to remove the ring gear and put it back on the correct side..
If the wheel was used with a coupler. You will need to have the clutch surface area refaced at a machine shop as the surface is only rough turned in Marine app.
The only clutch bolt pattern is on the outer edge for a large 11" disc and p-plate.
Old 06-12-2007, 10:53 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I just saw my first the other day that was drilled for both clutch patterns, but who knows... could have been an automotive flywheel put in a boat
Otherwise, bobcrman has it spot on. Same castings, different prep.
Old 06-13-2007, 06:30 AM
BT74's Avatar
Thanks guys, the guy only wants $20 for it, anf $12 to ship it(30 miles..but it's on the other side of Boston, not the most pleasant drive) so it sounds like a pretty good deal. I assume if the ring gear require relocation, it would be a matter of heating it up with a rosebud and moving and reinstalling it?
Old 06-13-2007, 08:34 PM
Correct. Tho I just knock the ring gear off with a hammer and large blunt chisel, then heat and re-install.
454 chevy marine engine wiretwister Engine 25 06-03-2014 06:11 PM
454 Flywheel Jim Vines Engine 3 07-18-2005 09:59 PM
is this flywheel for a 454? superrodder Transmission - Rearend 1 01-30-2005 10:59 AM
Chevy Big Block 454 Marine heads 71 nova Engine 4 09-03-2004 06:08 PM
Chevy 454 marine for the road Si Engine 2 10-10-2002 06:22 AM
