Marine VS Standard Spark Plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2009, 04:58 PM
70bird's Avatar
Smile if you know Jesus
Last journal entry: Waiting for a tranny
Can someone tell me the difference between a Marine plug and a standard automotive plug?
My crate BBC called for the ACDelco MR-43T spark plugs but I've done some mods that will increase cylinder pressure so I want to go to a slightly cooler plug which would be a MR-44T.
The local parts stores don't carry the MR series (Marine) plugs but they do have the standard R series plugs. I'm going to take an MR plug down and compare the dimensions but at a glance they look identical.
I've noticed that other brand's standard plugs cross reference to the Marine plugs but there has to be some difference.
I sent ACDelco an email asking the same question but have yet to receive a reply.
Old 08-29-2009, 05:46 PM
ericnova72's Avatar
More for Less Racer
Your going the wrong way, from a 43 to a 44 plug would be going hotter in AC plugs.
Old 08-29-2009, 05:54 PM
70bird's Avatar
Thanks.
I was thinking about how Autolites are numbered.
Old 08-29-2009, 05:56 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
This is from the Champion web site:
Champion offers spark plugs for all marine applications, such as inboards — including diesel engines that require glow plugs — outboards, jet boats or personal watercraft (PWC). Champion’s marine plugs also have stainless steel threads that never rust, are easy to remove and are particularly well-suited for saltwater environments.
Champion marine spark plugs have an extruded copper core in the center electrode that maintains accurate control of heat range, optimizing the performance and longevity of the spark plug. They start easily and won’t leave marine equipment operators stranded.
The electrodes on Champion marine spark plugs use our Heat-Active™ alloy to reach operating temperatures quickly and maintain stable operating temperatures under varying engine loads.
Champion marine spark plugs also have a patented Mag Suppressor that provides maximum protection from radio frequency interference (RFI) in GPS/fish finders.
AC Delco, not so easy to find specifics.
Old 08-29-2009, 06:03 PM
bondo's Avatar
Ayuh,.... dimensionally, they Are the same...
The Only difference is, the Marine plugs are of an Alloy Body..... Less Rust....
Old 08-31-2009, 09:29 PM
70bird's Avatar
Here's the official response from ACDelco. Basically repeating what was already said here.
_______________________________________
The only difference is marine and non-marine. ACDelco marine plugs feature
a nickel-plated, rust resistant shell on all applications, and a clipped
side electrode on some applications. These plugs are designed for higher
RPM engines. They also have a larger heat sink, and the porcelain is not
only pressed into the heat sink, it is glued.
Spark plugs must operate within certain limits if they are to provide the
performance and service life expected. Engine manufacturers select a type
of spark plug for the normal or expected service for which the engine was
designed.
The heat range, which is designated by the second numeric digit (second 4)
is the same in both spark plugs.
________________________________________
Old 09-04-2009, 07:33 PM
tnovot's Avatar
The first numeral being a 4 is the same in both but the SECOND numeral, one being a 4 and one being a 3, are NOT the same.
Ericnova is correct, the 43 is colder than the 44.
Terry
Old 09-05-2009, 10:41 AM
70bird's Avatar
He comment on being the same heat range was when comparing the MR44T to the R44T.
Thanks
how soon can i check the spark plugs SBCfan04 Engine 7 04-01-2009 06:35 AM
Testing Spark Plugs off of 120VAC? 71gtx Electrical 2 03-10-2009 11:50 AM
need help finding the right spark plugs Icelander Engine 1 02-19-2009 08:27 PM
Chevy 454 Spark Plugs Selection Help leejoy Engine 12 10-02-2006 12:05 AM
what spark plugs are best? 72 chevy elcamino Engine 4 07-12-2005 08:59 PM
