Markings on a sbc 3970010 block - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2008, 11:35 AM
My new post is what are the raised bumps on some of the engines next to the block casting numbers; a circular pattern of ten dots with a pointer (looks like an arrowhead in the middle of the circle). On the left side of the circle of dots is a number 3 and the arrowhead symbol on the inside of the circle points to it. On the right side - outside of the circle is a letter N and to the right of it and up is a raised O with a V stamped in the O, and then below that is another symbol that looks like a large "a" not capital A. These last three form a triangular grouping located to the right of the circle of dots which are to the right of the casting number. I have this on one of my 3970010 with a H287 build date. Any ideas. I also see a lot of blocks with 38GM, or GM51 or 5TGM or 5.0 GM. The one I can't identify is 38GM. Any ideas?
Old 08-12-2008, 11:43 AM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
These are date stamps put on by the engine factory to identify shift, core changes, modifications etc.
Old 08-12-2008, 11:58 AM
re: Markings on a sbc 3970010 block
Thanx, any source where I can find what it describes. For instance, if a mod was made.
Old 08-12-2008, 12:35 PM
nitro_baller4692's Avatar
floppers forever
http://www.nastyz28.com/chevy-engine-code-stampings.php
here its in the knowledge base
SBC #3970010 is this a good block ? solidaxel Engine 59 07-26-2011 12:21 PM
Horsepower rating for sbc 4 bolt main block? beemdubya Engine 15 10-29-2009 06:52 AM
Looking to ID these holes in SBC block mr52pickup Engine 24 12-13-2007 10:41 PM
SBC Question 400 block Jag Daddy Engine 41 06-18-2007 09:31 PM
What should I ask for my SBC 400 block? NitrousJunkie Engine 8 07-11-2006 03:11 PM
