Maroon scotch brite before sealer/paint? ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2010, 11:56 AM
There were some spots hard to get to with sandpaper so with that being is it okay to breeze over those surfaces with maroon scotch brite? I broke through past primer so I plan to seal everything up with spi's epoxy primer reduced and then shoot base/clear.
Old 05-10-2010, 12:22 PM
302 Z28's Avatar
Yes, but the red or maroon Scotch Brite pads can be very aggresive if you push down too hard, so light pressure only.
Vince
Old 05-10-2010, 12:29 PM
great thanks vince
is there anything finer than the maroon scotch brites?
Old 05-10-2010, 12:32 PM
302 Z28's Avatar
Originally Posted by blgli
great thanks vince
I think the gray ones are, but I could be mistaken as I only use the red.
Vince
Old 05-10-2010, 01:01 PM
Underground's Avatar
Last journal entry: 54
The grey ones are finer. They even make a white for blending basecoats.
Old 05-11-2010, 11:37 AM
I use to wore out or used red one
Old 05-17-2010, 05:26 AM
deadbodyman's Avatar
Wiki Edits: 11
Red ones are for paint
gray are for clear...
Pistons scotch brite ekacpuc Engine 7 04-19-2010 08:12 AM
3m scotch brite pads and grinders? shanjesnen Garage - Tools 2 03-24-2008 04:30 PM
Scotch Brite Questions!! jimmy1 Body - Exterior 16 02-11-2008 03:31 PM
Red Scotch Brite Pads At Lowes? SHIFTY101EASY Body - Exterior 4 06-15-2007 09:55 AM
scotchbrite uses fitzwell Hotrodding Basics 13 09-29-2006 12:04 PM
