Maroon scuff pad to prep clear coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2012, 06:07 PM
67Elcamino's Avatar
Im usin 600 grit wetsand to knock down the orange peel on my first coat of clear before applying two more coats. I wanna finish sanding the low spots with a maroon scuff pad but was wondering what is the pad equivalent grit to sandpaper?
Old 06-02-2012, 08:35 PM
Maroon pads are equal to about 320-400 grit.
I wouldn't use those for leveling clear.
Gray pads are closer to 600 grit.
Be very careful about sanding through
the clear with only one coat on.....
Old 06-02-2012, 11:33 PM
They sell scuff pads in 2 thicknesses, the standard size for regular work and 1/2 thickness for paint prep. Check your supply store for the ones you want for prepping clearcoat.
Old 06-03-2012, 05:57 AM
deadbodyman's Avatar
Wiki Edits: 11
The gray pads are for scuffing clear coat.Red is for paint prep
Old 06-03-2012, 11:15 AM
if you want good sanding pads check on ebay look under bowling ball pads
these go from 600 grit up to 4000. about 15.00 for 6 u can use these with your DA too and they last a long time
Afraid to color sand my new base coat / clear coat. Can I go straight to fine cut? Zeeb Body - Exterior 12 06-12-2012 09:36 PM
spraying clear coat on top of clear coat? bennecc Body - Exterior 9 05-08-2012 04:59 AM
spot repair of metallic black base coat clear coat on bumper bar pinkotoo Body - Exterior 0 02-25-2012 04:35 PM
Clear Base coat vs Clear Top coat waterdude Body - Exterior 7 12-13-2010 11:11 AM
Scuff pad-gray or red jcclark Body - Exterior 4 05-11-2005 05:13 AM
