masking tape - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2008, 04:59 PM
zephyrc's Avatar
masking tape
i need to mask on to a basecoat for stripes.. is there a specific tape to use that is low tack,, as i am worried about pulling the basecoat up with the tape.. how long after spraying the base coat can i mask over it and how long have i got before i must put the clearcoat on
Old 11-07-2008, 05:07 PM
Well, if you look at the p-sheet it will have a "to tape" time... there you are.
Old guy's tip- tape the tape to your shirt or pants first, then tape the basecoat. It won't stick as well that way.
Remove the tape as soon as the stripes tack up.
Old 11-07-2008, 05:22 PM
302 Z28's Avatar
3M "Fineline" tape will return a super sharp line, lifts easily, and goes around corners great. If you can't find it then any high quality auto grade masking tape will suffice. When removing it pull it back onto itself rather that straight up. Do not be tempted to use store brand masking tape .
Vince
Old 11-07-2008, 08:52 PM
BMM BMM is offline
3M fineline, Ive never had a problem with. The green stuff is not so strechty, so it works great for straight lines. The blue stuff is strecthable for curves, corners etc.
Old 11-07-2008, 10:40 PM
I use the 3m blue fine line tape for any and all lines that need a clean crisp edge. I wouldn't use anything else to mask out your stripes. Your base shouldn't pull up if the primer is properly prepped. However you can get tape residue transfer on the base if you pull too tight of an angle. i
window install Jzarczyn Body - Exterior 10 01-25-2009 12:02 AM
How do I remove widsheild/rear window trim from 65 GTO without damage? smallblocker2 Body - Exterior 10 06-25-2007 12:40 AM
"Basics of Basics" Reverse masking for two tones MARTINSR Body - Exterior 0 03-13-2007 12:32 AM
Installing back glass on 66 gto.. help beemdubya Body - Exterior 4 10-12-2005 11:32 PM
When To Take Off Masking And Pinstriping Tape JimKramer Body - Exterior 3 04-20-2005 02:13 PM
