Masking Tape on Base Coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2011, 08:01 AM
So I am going to do some graphic's on a boat (not that that matters). But will be using a base clear, my questions is after i am done spraying the first color of base how long should I wait till i can mask of a section? Just till it flashes? I have done a few solid colors but have never done any sort of stripes or graphic or anything. Thanks
Old 04-26-2011, 08:46 AM
302 Z28's Avatar
The masking tape will be fine if you use the proper tape. Ordinary beige tape is a no non, specially on fresh base. Go to an automotive paint vendor and purchase a roll of 3M Fine Line tape. It is available in various widths. Also purchase some 3M green tape, use the Fine Line tape to establish a sharp line edge then offset a little with the green tape to finish your masking. When finished with your stripes be sure to remove all the tape by pulling it back on itself and not straight up.
Vince
3M masking tape onebadmerc Body - Exterior 16 01-03-2009 06:00 PM
Masking tape prblem. dkipp Body - Exterior 6 11-15-2008 01:41 AM
masking tape zephyrc Body - Exterior 4 11-07-2008 09:40 PM
removing masking tape residue on base???? Saddlebacks Body - Exterior 7 05-20-2007 07:26 PM
When To Take Off Masking And Pinstriping Tape JimKramer Body - Exterior 3 04-20-2005 01:13 PM
