Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Masking tape prblem.
Old 11-14-2008, 06:58 PM
yknot yknot is offline
Last journal entry: More on the Cobra Engine
On the painting in cold weather thing.....Make sure your manufacturer is OK with those cold temps, usually 70� is the lowest you can paint in. Also be aware that many paints will not dry in cold weather, in fact House of Kolor paints will just lie dormant till the temps warm up over 65�. Meaning you will have GREEN paint or paint that has not cured for months till the temps reach above 65�. This is very important because you can ruin a paint job by assuming it's cured when it hasn't.
