Masking tape prblem. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2008, 05:53 PM
Hi Guys; Here is the deal. I have my roadster totally ready for paint. It is primed and I just finished taping and masking it. I live in Northern Ohio and the temp. has gone from mid 60s to mid 30s. Great! how long can I leave the masking tape on before I paint in very low temps with out problems. It looks like it could be weeks before I get a temp that is above 50 . Thanks for your help. I used very good tape.
Old 11-12-2008, 06:12 PM
boatbob2
tape...
HI,if you used the blue tape,you should be good for months. if yellow tape,take it off now...
Old 11-14-2008, 04:07 AM
Which tape is better. The blue tape or the green auto tape?
Old 11-14-2008, 07:42 AM
302 Z28's Avatar
Blue tape is for house painting, the green tape is what you want.
Vince
Old 11-14-2008, 09:03 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Like Vince stated...blue is for house, green is for cars.DO NOT use the yellow/beige as you will get residue off of it. And don't try and save by buying the green at the Advanced, AZ's. or Wally. Same tape but core size is remarkabely larger, so less per roll. Way less at the same price.
Old 11-14-2008, 07:58 PM
Last journal entry: More on the Cobra Engine
On the painting in cold weather thing.....Make sure your manufacturer is OK with those cold temps, usually 70� is the lowest you can paint in. Also be aware that many paints will not dry in cold weather, in fact House of Kolor paints will just lie dormant till the temps warm up over 65�. Meaning you will have GREEN paint or paint that has not cured for months till the temps reach above 65�. This is very important because you can ruin a paint job by assuming it's cured when it hasn't.
Old 11-15-2008, 02:41 AM
How long does it usually take for the paint to cure when it is 65 or above?
How do I remove widsheild/rear window trim from 65 GTO without damage? smallblocker2 Body - Exterior 10 06-25-2007 12:40 AM
"Basics of Basics" Reverse masking for two tones MARTINSR Body - Exterior 0 03-13-2007 12:32 AM
Basic of Basics - Windshield Installation Kits firebird_red Body - Exterior 15 11-26-2005 10:00 PM
Installing back glass on 66 gto.. help beemdubya Body - Exterior 4 10-12-2005 11:32 PM
When To Take Off Masking And Pinstriping Tape JimKramer Body - Exterior 3 04-20-2005 02:13 PM
