mason dixon line. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2010, 08:34 AM
Last journal entry: Hood
mason dixon line.
Maybe a dumb question but I just have to know.....why is it a rule of thumb that if you live on the south of the mason dixon line you shouldn't wet your floors when you paint?
Old 10-28-2010, 09:04 AM
BarryK's Avatar
Only applies to higher medium and high solids clear and clears with the higher grade resins.
Humidity must be 50% or more to affect, paint like you said you use at your shop ,are not affected, one way or another.
Old 10-28-2010, 10:13 AM
Ahhh alright, I remember having a conversation on the phone with you a while back about this subject. You remember what paint I said I use at our shop? As a matter of fact I do need to call you at some point reguarding the fiberal to epoxy adhesion test you had done, been super busy and now I'm vacationing in tennessee so when I get arond to it I'll call.
Holley fuel pump, return line or not to return line??? JD's camaro Engine 1 07-16-2010 05:17 PM
Line lock on rear wheel Bandit1980 Suspension - Brakes - Steering 13 03-12-2010 05:53 AM
fuel return line - 79 chevy 1/2 ton Torque454 Engine 7 02-24-2010 11:32 PM
Fuel return line (carbed) - where? McDesign Engine 5 01-24-2010 09:13 AM
Can 2 line brake system be converted to 4? Neophyte Suspension - Brakes - Steering 8 03-07-2005 08:22 PM
