Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Massive oil leak after distributor install
  #20 (permalink)
Old 07-18-2013, 01:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Lovemius View Post
I put the RTV around it thinking it would hold. I'm thinking that was not a good idea. LOL.
I've also been told to use a copper type hose instead..... Anyone know what I am referring to.
I'm learning as I go along. You guys have been a great help. I was about to put a new gasket on my oil pan, because I thought that was the issue.
There are oil pressure gauge line kits in either plastic or copper. OEMs used copper for years, then began using plastic. Either will work but a lot can depend on the use and how it's routed. Obviously copper will withstand high temps better, plastic is less likely to kink if bent tightly.
Ideally you'd protect the line (either type) wherever it touches another component or passes through the firewall, etc.
