Massive oil leak after distributor install - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-15-2013, 07:32 PM
Killeratrod, you know what I meant brother! Just realized what I was saying. Yes, a few quarts. This may be a the problem.
  #17 (permalink)
Old 07-16-2013, 06:15 PM
That will cause the problem!!! who put all the RTV around it?
  #18 (permalink)
Old 07-16-2013, 10:04 PM
lhmurphy's Avatar
At least it didn't decide to start spraying oil on the way home! glad you found the problem! I like posts where people find the actual problem and come back and show the solution. Its good for the forum.
  #19 (permalink)
Old 07-17-2013, 03:59 PM
I put the RTV around it thinking it would hold. I'm thinking that was not a good idea. LOL.
I've also been told to use a copper type hose instead..... Anyone know what I am referring to.
I'm learning as I go along. You guys have been a great help. I was about to put a new gasket on my oil pan, because I thought that was the issue.
  #20 (permalink)
Old 07-18-2013, 01:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are oil pressure gauge line kits in either plastic or copper. OEMs used copper for years, then began using plastic. Either will work but a lot can depend on the use and how it's routed. Obviously copper will withstand high temps better, plastic is less likely to kink if bent tightly.
Ideally you'd protect the line (either type) wherever it touches another component or passes through the firewall, etc.
  #21 (permalink)
Old 07-20-2013, 02:04 PM
OIL leak
Sounds like it's the oil pressure guage/sender fitting next to the back of the intake manifold. Have you checked that. Do yourself a favor and do not use the Nylon (plastic) type hose to the mechanical guage, It will eventually fail. Use copper tubing. I always make a about 1 1/2" loop in the copper tubing before going through the firewall to the guage. This allows for tubing to take up the flex and slight engine movement when using rubber engine mounts without damaging the copper tube. Also if you go to a NHRA dragstrip it is against the rules to have a plastic oil line, something you do not want going into the passenger compartment. I know I don't want hot oil spraying on my leg.
how much oil can the distributor gasket leak on a sbc? zoomo Engine 3 05-30-2011 11:47 AM
Distributor install 4Speeduser Electrical 4 04-08-2007 03:15 PM
302 distributor oil leak Wooky71 Engine 4 12-19-2005 10:08 PM
Oil leak at MSD distributor base? TVR383 Engine 2 10-28-2005 03:37 PM
massive oil leakage Scuzzy Engine 2 09-03-2003 08:41 PM
