master and booster problem/c5 conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2010, 06:19 PM
I'm working on a 68 chevelle and doing a custom corvette c5 brake conversion. going from 4 wheel drums to front disc and rear drum
I am going to put a manual master on from a 77-78 malibu and see how i like it.. I work at a parts store so its a cheap test. But I'm thinking I should just go ahead and install power brakes.
I was told to use the stock 68-72 booster and use a 2000 s10 master? how can that work? the rod that drives the cylinder in the master is at least 2" to long. if you look at a booster from a s10 it has a small little "nipple" (lol) thay drives the master cylinder.
Now has anyone used a camaro master from like a 98-02 or 93-97? I notice some people used a 95 camaro master and booster for a 67-69 camaro with a c4 conversion.
1.) Can u still use the 68-72 booster? if i would cut that shaft down? idk if that would still work? wouldn't that change the depth of the pedal?
2.) If i had to use a late model booster.. would i be better off using a camaro booster from 93 to 02? If i did use one.. it looks to be a challange to mount up and get the "right angle"
3.) another ? is why a s10 master? If there brakes are to small to did a conversion?
Anyone have ideas on what to use or problem fix?
thanks tony
Old 01-08-2010, 10:24 AM
good choice of brakes. thats a really big car to stop. personally, i would either use a master cyl/booster and proportioning valve from either a two wheel drive full size truck, or a third gen camaro. i would think the third gen setup would be a little better matched, but the truck one may have the added capacity for a heavier vehicle. your choice.
Old 01-09-2010, 09:13 AM
Mechanic
have you thought about using the master and booster from a caprice, say 85- 92 pretty common stuff and all the piston sizes should be pretty close to what you are trying to setup
Questions about master cylinder and brake booster mike69 Suspension - Brakes - Steering 1 08-15-2009 09:42 AM
Master cylinder without booster? Rons1stRod Suspension - Brakes - Steering 16 11-05-2007 09:06 PM
using only the master cylinder and takin out the break booster Arillious Suspension - Brakes - Steering 12 08-14-2007 11:02 AM
Master cylinder to fit 8" dual booster jcarter Suspension - Brakes - Steering 7 05-25-2006 01:13 AM
