-   -   Master clutch cylinder choice? (http://www.hotrodders.com/forum/master-clutch-cylinder-choice-225607.html)
DjohnsonFTW 10-31-2012 08:59 PM
Okay so, i have a 1986 el camino that im putting a t56 in that came out of a trans am(96?)
its installed and i have pedals out of an F body installed, but the master/slave cylinder setup i got i cannot get to install at the angle i want... I have found what i think would work perfectly but i have an odd question..
Is any master clutch cylinder do-able for my situation or do i have to get a specific one? i just need the ability to adjust the rod... if someone could look at what i found and possibly steer me in the right direction i would greatly appreciate it
Dorman CM39903 .... UPC: 082702350706
Thanks!!!
S10xGN 11-01-2012 10:44 AM
You should stick with the same bore diameter and stroke length, other than that anything goes...
Russ
