Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Master cyinder losing fluid from cover
Old 06-08-2011, 01:39 PM
adantessr's Avatar
adantessr adantessr is offline
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
You would have to have a bad gasket on the cover for it to leak . The rubber gasket has sort of a diaphram function to allow for expansion of the brake fluid. Make sure that it is installed correctly. If the gasket is good and installed correctly, theoretically, you could turn the master cylinder upside down and not leak any fluid.
