Master cyinder losing fluid from cover
I have a disc/drum set-up, 7" booster with 82 Corvette master cylinder. I replaced both rear wheel cylinders and now have brake fluid leaking past the gasket between the lid and the body of the M/C when the car is driven. It was not leaking before I replaced the wheel cylinders. The system also has a prportioning valve which I suspect may somehow be the culprit. Any suggestions on what to check would be appreciated.
You would have to have a bad gasket on the cover for it to leak . The rubber gasket has sort of a diaphram function to allow for expansion of the brake fluid. Make sure that it is installed correctly. If the gasket is good and installed correctly, theoretically, you could turn the master cylinder upside down and not leak any fluid.
Thanks. I tried a new lid and gasket but it's still leaking.
Is the cover bail tight enough? Maybe a nick in the sealing surface of the master cyl.?
The cover fits tight. I think the key clue here is that there was no leak prior to replacing the wheel cylinders, so the leak is perhaps due to something I did while bleeding the system, or something I failed to do. Is it possible that replacing the wheel cylinders tripped something in the proportioning valve that's causing a pressure build up in the M/C to force fluid past the gasket whenever I depress the brake pedal? Or if the fluid level in the M/C dropped too low would failing to bench bleed the M/C cause this problem?
How old is the M/C? Does the fluid in the other reservoir go down? I had a problem once where one reservoir of my M/C would fill up and overflow like yours, but over time the other side lost fluid. There were no external leaks. I finally figured out that the internal seals in the M/C were worn and fluid was being pumped from one circuit to the other. A new M/C fixed the problem. I think you may have disturbed the old seals in the M/C when you bled the brakes.
It is also possible that the seals in the combo valve are bad, allowing a similar transfer of fluid, but my money is on the M/C. Those are the only two places in the brake system where fluid from one circuit can flow into the other circuit if there's a bad seal. |
You may have hurt the master while bleeding for the new cylinders. As joe stated in the previous post fluid may be leaking between the front and rear reservoirs. Try taking some fluid out of bot so they are down a quarter inch or so. Drive it and see if one side fills back up.
I dropped the fluid level but it still overflows. I had a friend depress the brake pedal while I watched the master cylinder with the lid off and it was like Old Faithful! Brake fluid was shooting up out of both reservoirs. Is that normal? Still not clear to me how it's getting past the gasket. I guess I'll try a new M/C and see if that clears it up.
I dropped the fluid level in both reservoirs. Every time it overflowed, I took the lid off and both reservoirs were approximately at the same level as before and it did not appear as though one reservoir was gaining fluid at the expense of the other.
I replaced the master cylinder and so far there's been no more fluid overflowing from the rear reservoir. Thanks to all for their comments and suggestions!
| All times are GMT -6. The time now is 03:41 PM. |
