Master cyinder losing fluid from cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2011, 12:23 PM
I have a disc/drum set-up, 7" booster with 82 Corvette master cylinder. I replaced both rear wheel cylinders and now have brake fluid leaking past the gasket between the lid and the body of the M/C when the car is driven. It was not leaking before I replaced the wheel cylinders. The system also has a prportioning valve which I suspect may somehow be the culprit. Any suggestions on what to check would be appreciated.
Old 06-08-2011, 12:39 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
You would have to have a bad gasket on the cover for it to leak . The rubber gasket has sort of a diaphram function to allow for expansion of the brake fluid. Make sure that it is installed correctly. If the gasket is good and installed correctly, theoretically, you could turn the master cylinder upside down and not leak any fluid.
Old 06-08-2011, 12:48 PM
Thanks. I tried a new lid and gasket but it's still leaking.
Old 06-08-2011, 01:42 PM
Is the cover bail tight enough? Maybe a nick in the sealing surface of the master cyl.?
Old 06-08-2011, 01:48 PM
The cover fits tight. I think the key clue here is that there was no leak prior to replacing the wheel cylinders, so the leak is perhaps due to something I did while bleeding the system, or something I failed to do. Is it possible that replacing the wheel cylinders tripped something in the proportioning valve that's causing a pressure build up in the M/C to force fluid past the gasket whenever I depress the brake pedal? Or if the fluid level in the M/C dropped too low would failing to bench bleed the M/C cause this problem?
Old 06-08-2011, 02:39 PM
How old is the M/C? Does the fluid in the other reservoir go down? I had a problem once where one reservoir of my M/C would fill up and overflow like yours, but over time the other side lost fluid. There were no external leaks. I finally figured out that the internal seals in the M/C were worn and fluid was being pumped from one circuit to the other. A new M/C fixed the problem. I think you may have disturbed the old seals in the M/C when you bled the brakes.
It is also possible that the seals in the combo valve are bad, allowing a similar transfer of fluid, but my money is on the M/C. Those are the only two places in the brake system where fluid from one circuit can flow into the other circuit if there's a bad seal.
Old 06-08-2011, 09:39 PM
T-bucket23's Avatar
Wiki Edits: 26
You may have hurt the master while bleeding for the new cylinders. As joe stated in the previous post fluid may be leaking between the front and rear reservoirs. Try taking some fluid out of bot so they are down a quarter inch or so. Drive it and see if one side fills back up.
Chet
Old 06-10-2011, 07:03 PM
I dropped the fluid level but it still overflows. I had a friend depress the brake pedal while I watched the master cylinder with the lid off and it was like Old Faithful! Brake fluid was shooting up out of both reservoirs. Is that normal? Still not clear to me how it's getting past the gasket. I guess I'll try a new M/C and see if that clears it up.
Old 06-11-2011, 08:15 AM
Let's ask the question again. You dropped the fluid level. When it started to overflow, was the level HIGHER than when you started? Was it in both reservoirs or just one? Was the other one lower than when you started?
Old 06-11-2011, 11:34 AM
I dropped the fluid level in both reservoirs. Every time it overflowed, I took the lid off and both reservoirs were approximately at the same level as before and it did not appear as though one reservoir was gaining fluid at the expense of the other.
Old 06-17-2011, 12:58 PM
I replaced the master cylinder and so far there's been no more fluid overflowing from the rear reservoir. Thanks to all for their comments and suggestions!
Old 06-17-2011, 03:51 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Glad you got it fixed. :-)
Tractor fluid instead of regular tranny fluid! Studebaker Transmission - Rearend 24 10-17-2012 07:44 AM
Brake Lines Master Cyinder f7firecat Suspension - Brakes - Steering 1 01-17-2011 10:29 AM
Bad master cylinder, caliper or brake fluid? bujjiammulu Suspension - Brakes - Steering 1 05-10-2010 07:58 AM
master cylinder cover? 49fordp/u Suspension - Brakes - Steering 6 06-09-2009 05:23 PM
Master Cylinder losing fluid jboy Suspension - Brakes - Steering 6 05-05-2004 06:01 PM
