Master Cyl Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2011, 12:15 AM
Rob_the_ToonMan's Avatar
I want to upgrade my 56 Chevy's single Master Cylinder do a dual unit. I am not going with Power Brakes. Any reccomendations on what Master Cylinder to use.
Old 04-25-2011, 07:47 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Might start with a 67
Chevelle
Impala
master cylinder-------67 is the first year of the tandem master for GM.
Might also need to get a distribution block/valve.
This piece senses a failure in the system and will shut off the failed circuit
Old 04-25-2011, 08:06 AM
delawarebill's Avatar
m/c
what ever m/c u finally go with... buy a NEW one not a rebuilt unit...
Old 04-25-2011, 08:44 AM
302 Z28's Avatar
X2, brake components is not an area to try and save a buck.
Vince
Old 04-25-2011, 09:00 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Disc/drum, drum/drum, or what?
If using stock drums front and rear, a late '60's- early 70's midsize Chevy donor will work. Before that in '70, the brake distribution block and hold off valves, etc. were still somewhat in transition. The final move to the "combo" valve was still occurring, IIRC. Beginning about '71, combination valves were being used. So if you want to use a combo valve, go w/something later than '71 or so.
Old 04-25-2011, 09:12 AM
I have a 55 and used a 68 chevy MC with drums all around.Bolts right up and I ran new lines all around.I didn't use any type valves and it will stop on a dime.
Old 04-25-2011, 07:21 PM
Great info guys thanks!!!! I am running drums on all four corners, so this helps me a lot!!!!!!
Thanks!!!!!!
1966 Thunderbird Master Conversion Liveaxle Suspension - Brakes - Steering 4 03-12-2013 01:52 PM
master and booster problem/c5 conversion chevelle327C5 Suspension - Brakes - Steering 2 01-09-2010 10:13 AM
1959 fairlane dual master cylinder conversion? djtrickee Suspension - Brakes - Steering 1 05-20-2008 03:03 PM
disc brake conversion master cylinder Eric64 Suspension - Brakes - Steering 9 09-26-2006 04:19 PM
master cyl nomad58 Suspension - Brakes - Steering 2 06-15-2003 10:32 PM
