master cyl routing - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2008, 08:54 AM
master cyl routing
Hi
when installing a new brake set-up if the master cyl is a dual one whether u have disks or drums does the big reservoir always feed the front brakes?
thanks
Old 02-08-2008, 09:18 AM
powerrodsmike's Avatar
Wiki Edits: 161
Every one I have ever seen does. The big reservior is necessary to feed disc brakes the amount of fluid they need to compensate for pad wear. There is no real difference in the piston, or bore...But if you have a MC that is supposed to feed drum brakes all around it may have RPV valves installed in the ports , just under the inverted flare seat.
Take a paperclip or piece of wire and gently probe the port(s). If there is an RPV valve you will feel a soft plug about 1/4" in ...no RPV and you can push the paperclip in a god ways.
Dont use an RPV equipped MC port with disc brakes attached to that port.
If you have an RPV in one port only, that port needs to hook to rear drums.
If you have a 4 drum system, you can add 10# RPVs to the system if your MC doesn't have any .
What exactly is your system? 4 wheel disc? 4 w drums? disc/drum?
Later, mikey
BE different....ACT normal.
Old 02-08-2008, 09:48 AM
right now it is all drum,but in the future I will probably be putting disks on the front .I bought 2 #10 valves and a adjustable proportional valve,my MC used to be on the fire wall & I'm moving it to the frame,I bought a bracket & pedal assy & MC (kit) from speedway and am just in the process of starting to install & don't want to goof up!!!
Old 02-08-2008, 10:03 AM
Wiki Edits: 161
Go ahead and install the 10# RPV's in your lines ...Just make sure that you switch the front RPV out for a 2# when you upgrade to front discs.
Double check that you don't have an RPV already installed in the port that will go towards the fronts. It probably doesn't, but you never know.
Later, mikey
Old 02-08-2008, 10:55 AM
P did the paperclip thing and I don't feel nothing,so I don't think there is any in the MC
thanks
Stock Monza Master Cyl work with aftermarket disk brakes? Quarter Flash Suspension - Brakes - Steering 1 11-19-2006 05:31 PM
large bore master cyl maninacoupe Suspension - Brakes - Steering 14 10-16-2006 06:02 AM
brake master cyl question! 67 Deuce 4 Me Suspension - Brakes - Steering 3 08-08-2006 12:47 AM
Relocating master cyl on a 34 302 Z28 Suspension - Brakes - Steering 8 11-16-2003 10:42 AM
Master cyl. subdude Hotrodders' Lounge 4 06-26-2002 07:17 PM
