master cylender brake peddle very soft - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2007, 09:57 PM
Last journal entry: 52 belair frame off
Hi guys. Just installed an after market cylinder on my 52 chevy car . Equipped with front disk brakes/rear drums 10psi/5psi reduced valves. Peddle goes all the way down when compressded.
Old 12-28-2007, 10:24 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
You will have to bleed the brakes.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 12-29-2007, 02:44 PM
Brake system needs further bleeding
I guess I need to do a better job at bleeding them. I'll attempt to do that today.
Old 12-29-2007, 10:28 PM
did you bench bleed the master cylinder before you put it on? if you didnt you will take a long time bleeding them you wil get fluid but that will be old after that you will get air pockets from the new cylinder then you will get new fluid and be okay
Old 12-30-2007, 07:52 PM
MC bleeding
I sure did not bleed the MC before plumbing. I will take more time bleeding the lines now.
new master cylinder, bleed still no brake! customdrumfinishes Suspension - Brakes - Steering 11 11-05-2006 07:07 PM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Universal Master Cylender Amoretti Suspension - Brakes - Steering 7 08-16-2002 11:58 AM
