Master Cylinder... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-07-2011, 02:27 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by sscardino
I'm expecting the rebuild kit today. My first rebuild of a M/C...
Nothing to it. Just remember, cleanliness is next to Godliness.
  #17 (permalink)
Old 05-07-2011, 07:42 PM
sscardino's Avatar
SF48
Ah Man...
I bread the M/C, with a home made bleeder, bolted it onto the firewall. I went to start the car, as it has sat for a week to charge the battery. I think now the started solenoid is out. Uuurrggg...
When it rains...
  #18 (permalink)
Old 05-07-2011, 10:02 PM
Wiki Edits: 326
Run some new grounds. Don't take any off, just add some, body to frame, frame to motor block.
  #19 (permalink)
Old 05-10-2011, 12:42 AM
chevyrestore's Avatar
if you rebuild that cylinder yourself make sure you use some grease for those seals. theres a special grease we use on a lot of them...if theres a pushrod between the cylinder and pedal make sure its there and its the correct one.
  #20 (permalink)
Old 05-10-2011, 01:57 PM
sscardino's Avatar
SF48
M/C Bleeding
Due to my back stuff, I just was able to bleed the brakes after replacing the M/C. I'm getting a lot of air out of the lines. Is that to be expected. I bled the brakes and don't recall this much air... It has been awhile
Thanks
  #21 (permalink)
Old 05-10-2011, 06:06 PM
sscardino,
I would have bleed the master cylinder on the bench. Then install it in the vehicle and just bleed the fitting at the master cylinder.
But now you have to bleed the system until there is no more air bubbles coming out of the bleeders. Look on the bright side...you will have all new fluid in the system when you are finished.
Charge the battery before you replace any parts. If you know the battery is good then move on to the next item. Solenoid maybe. If it does not make a sound or if it just clicks.
To be sure connect a battery jumper cable from the positive battery terminal to the starter connection. That is the bolt that goes into the starter. If the starter turns then yes the solenoid needs to be replaced.
Have Fun
Scholman
  #22 (permalink)
Old 05-10-2011, 08:29 PM
sscardino's Avatar
SF48
M/C - Starter
I rebuilt the M/C and bench bled it, still Huh i.e. a lot of air while I replace all of the brake fluid.
I bench tested the starter, it's shot. I ordered a rebuilt yesterday.
Thank you for your impute, I do appreciate it!
SS
  #23 (permalink)
Old 12-30-2011, 07:05 AM
Cape Cod Bob's Avatar
Just following up to see how you made out ?
  #24 (permalink)
Old 12-30-2011, 09:51 AM
sscardino's Avatar
SF48
Cape Cod Bob - Master Cylinder
Thank you for following up with me. I really appreciate that! Yea, all worked out great. All the air I was getting a lot was coming from the one person brake bleeder.
I have plenty of peddle, slows and stops fine.
Thanks again,
Steve
master cylinder wayneooo Suspension - Brakes - Steering 1 09-19-2010 02:32 PM
GM master cylinder ? lanierledford Suspension - Brakes - Steering 1 03-06-2010 01:31 PM
Master cylinder 49dream Suspension - Brakes - Steering 3 06-25-2006 04:23 PM
Master Cylinder Rod spanky36 Suspension - Brakes - Steering 4 03-20-2006 02:50 PM
Master cylinder fred56 Suspension - Brakes - Steering 2 10-15-2003 11:04 AM
