-   -   Master Cylinder... (http://www.hotrodders.com/forum/master-cylinder-197445.html)
sscardino 04-28-2011 09:46 PM
Master Cylinder...
I bought a prebuilt 31 Chevy Street Rod about 6-7 yrs back, the master cylinder is out, soft peddle going slowly to floor, I bled the brakes. Still no brakes. it has brake drums all around.
How do I know which master cylinder replacement to buy?
Thought, opinions, ideas?
techinspector1 04-28-2011 11:50 PM
Take it apart and measure the bore. Post a photo, maybe someone will recognize the make and model. If you like the way the brakes feel to you now, then replace it with another cylinder with the same bore size or rebuild the one you have. If you want the car to be easier to stop with less leg pressure than you currently have to give, then go with a smaller bore size cylinder. The pedal will travel further, but the car will stop easier. If the pedal travels too far now and the brakes are touchy, then you can go with the next up bore size. It will require more leg pressure to stop the car, but the pedal travel will be reduced.
sscardino 04-29-2011 11:31 AM
Master Cylinder
Thank you, I'll do that this weekend. I appreciate you impute!
Steve
bentwings 04-29-2011 06:48 PM
If it is an under the floor MC check the rod end of the piston. There will be either a hole or just a counter sink. If I remember power brakes have the hole. both bore sizes are available.
sscardino 04-29-2011 07:46 PM
M/c
Thanks! It all helps.
Cape Cod Bob 04-29-2011 07:55 PM
Checkm out these guys for more info. Order their catalog. It has a lot of good info and diagrams in it. :)
http://www.mpbrakes.com/
sscardino 04-29-2011 08:12 PM
M/c
I sent for the catalog, thank you.
sscardino 04-30-2011 01:19 PM
Help: Can anyone ID this master Cylinder, make/year?
4 Attachment(s)
This are pix of my M/C, I believe it to be a chevy. It is a 31 chevy w/327, standard brake system, drum all around. The bore on the M/C is 1" across.
This car can be frustrating running down parts. A hell of a lot of fun working on it and mostly driving her.
Thank Guy's,
Steve
scholman 04-30-2011 02:56 PM
sscardino,
It looks like the master cylinder out of my 55 chevy 210.
Scholman
techinspector1 04-30-2011 03:05 PM
http://www.speedwaymotors.com/Single...lain,8887.html
http://www.classicchevy.com/chevy-br...1955-1958.html
Thank you Scholman :thumbup:
poncho62 04-30-2011 04:06 PM
2 Attachment(s)
My 55 MC looked nothing like that....but it looks just like the MC on my 62...not a good pic
techinspector1 04-30-2011 04:28 PM
That cylinder is specified for '55-'64.
poncho62 04-30-2011 04:39 PM
My 55 was like this one......
http://cgi.ebay.com/ebaymotors/55-56...item2eb3528497
techinspector1 04-30-2011 06:00 PM
I'll bet that one would work too, as long as it's a 1.000" bore.
sscardino 05-07-2011 01:49 PM
Rebuilding
I'm expecting the rebuild kit today. My first rebuild of a M/C... :smash:
