Take it apart and measure the bore. Post a photo, maybe someone will recognize the make and model. If you like the way the brakes feel to you now, then replace it with another cylinder with the same bore size or rebuild the one you have. If you want the car to be easier to stop with less leg pressure than you currently have to give, then go with a smaller bore size cylinder. The pedal will travel further, but the car will stop easier. If the pedal travels too far now and the brakes are touchy, then you can go with the next up bore size. It will require more leg pressure to stop the car, but the pedal travel will be reduced.
If it is an under the floor MC check the rod end of the piston. There will be either a hole or just a counter sink. If I remember power brakes have the hole. both bore sizes are available.
Checkm out these guys for more info. Order their catalog. It has a lot of good info and diagrams in it.
http://www.mpbrakes.com/ |
Help: Can anyone ID this master Cylinder, make/year?
This are pix of my M/C, I believe it to be a chevy. It is a 31 chevy w/327, standard brake system, drum all around. The bore on the M/C is 1" across.
This car can be frustrating running down parts. A hell of a lot of fun working on it and mostly driving her. Thank Guy's, Steve |
sscardino,
It looks like the master cylinder out of my 55 chevy 210. Scholman |
http://www.speedwaymotors.com/Single...lain,8887.html
http://www.classicchevy.com/chevy-br...1955-1958.html Thank you Scholman Last edited by techinspector1; 04-30-2011 at 03:13 PM. |
My 55 MC looked nothing like that....but it looks just like the MC on my 62...not a good pic
Ontario Rodders |
That cylinder is specified for '55-'64.
Ontario Rodders |
I'll bet that one would work too, as long as it's a 1.000" bore.
| master cylinder | wayneooo | Suspension - Brakes - Steering | 1 | 09-19-2010 02:32 PM |
| GM master cylinder ? | lanierledford | Suspension - Brakes - Steering | 1 | 03-06-2010 01:31 PM |
| Master cylinder | 49dream | Suspension - Brakes - Steering | 3 | 06-25-2006 04:23 PM |
| Master Cylinder Rod | spanky36 | Suspension - Brakes - Steering | 4 | 03-20-2006 02:50 PM |
| Master cylinder | fred56 | Suspension - Brakes - Steering | 2 | 10-15-2003 11:04 AM |
