which master cylinder? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2003, 10:46 AM
stea's Avatar
My brother in law has given me a brake pedal assembly from a 66 buick special for use in my 39 chev PU. Anybody know what master cylinder will work with this assemly? I considered a stock Buick cylinder but they all list for drum/drum and are single resevoir and I am set up for disc/drum.
Old 12-19-2003, 11:13 AM
302 Z28's Avatar
Most aftermarket brake installations use the Corvette dual master cylinder with a 1" bore.
Vince
Old 12-19-2003, 11:47 AM
stea's Avatar
But do all master cylinders have the same mounting pattern?
Old 12-19-2003, 01:41 PM
Pony's Avatar
Most auto mfgs make very few changes in this area. GMs seem to interchange easily. The big Buicks of the mid 70's thru mid 80's all run disk/drum. A trip to your local wrecking yard ( the ones that let you go in) should help you find what you need. My mc/power booster on mt Vette project was rusty and I went hunting in the local yard and wound up with a 1976 Buick Century set up. I had to modify the push rod slightly and am using my proportioning valve as the Vette has four wheel disks. The unit is about 10% bigger and should reduce pedal pressure the same. It bolted thru the firewall, cleared the engine and lined up with the pedal perfect. Generally speaking a bigger booster/master cylinder will give you a better brake system.
Old 12-19-2003, 08:33 PM
elcamino72's Avatar
Gearhead
I would just go with a disc/drum master cylinder from a 70's mid sized vehicle ... as the post above states, these are plentyful in the boneyards if you can find a good one or even one to use as a core ... even at the parts store these masters are relatively inexpensive.
Old 12-20-2003, 07:31 PM
302 Z28's Avatar
Use one from a wrecking yard as a core, rebuilt or new master cylinders are just too cheap to be using wrecking yard stuff.
Vince
Old 12-20-2003, 08:28 PM
poncho62's Avatar
Wiki Edits: 5
Are you planning on putting the brake pedal on the firewall or in the original position under the floor?
Old 12-21-2003, 01:28 PM
stea's Avatar
poncho, Implanning on the firewall.
Old 12-21-2003, 01:33 PM
poncho62's Avatar
Wiki Edits: 5
You will need to reinforce the firewall. Mounting a hanging brake pedal and master on the firewall puts a lot of strain on it. You don't want it to flex when you push on the brake.
It shouldn't matter if the nounting of a master that you decide on is the same as the Buick, you have to drill new holes anyways.
Old 12-21-2003, 05:20 PM
stea's Avatar
thanks guys, Firewall has been taken care off, I doubled up the metal when I smoothed it, its pretty stiff. I also welded a support brace behind the dash from side to side to hang the column from. Should be able to add additional support to the pedal assembly from this point too.
Old 12-22-2003, 02:30 AM
Pony's Avatar
When I added power brakes to my 53 Ford sedan I used the pedal assembly from a mid 70's T-Bird. Along with a place to hang the pedal I got steering column mounts and the assembly bolts up to the firewall and the brake booster then mounts to it. I used the T-Bird unit because it was handy and fit with almost no altering.
p.s. Page 2 in my gallery has a pretty good pic of the booster from the engine compartment.
Old 12-22-2003, 02:42 PM
Dave E Shank's Avatar
HEY STEA: On www.mpbrakes.com they show a number of universal street rod set up pedal and master cylinder combo's. It might give you an insight on what parts to use. I agree not to waste time and money on a wreck yard special ...The master clylinder may be the reason it is in the junk yard... GOOD LUCK...DAVE
Old 12-22-2003, 03:09 PM
46_stvblt's Avatar
Check out a MC from a 68-69 chev. Impala disc drum. I bought one from NAPA for about 40 bucks brand new, no core charge needed. works perfect...........GlennK
Old 12-22-2003, 06:01 PM
ets1945's Avatar
booster diameter??
What was the diameter of the 68-69 Impala booster? I have the tall Edelbrock valve covers for my rollers and have an interference problem.
Old 12-22-2003, 06:57 PM
46_stvblt's Avatar
The Booster I have is 11 inch but you can use a smaller one. I have the same problem you do with the valve covers but I can just barely get them off with much jockeying and afew choice words... I am going to get a smaller one in the future, but right now its working ok....GlennK
