Master Cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2005, 08:11 PM
46_stvblt's Avatar
Master Cylinder
I have a problem that I havn't run into before. My master cylinder is transfering the fluid from the rear reservoir to the front to the point that it started to leak out the top. Has anyone had this prob. or does anyone have any idea what the heck is going on? The MC is pretty new but I suppose it might be bad. IDEAS anyone????? Thanks....Glenn
Old 08-23-2005, 08:14 PM
poncho62's Avatar
Wiki Edits: 5
Probably, the rubber seal on the top is leaking, across the resevoirs and around the outside.
Old 08-23-2005, 08:36 PM
46_stvblt's Avatar
Master Cyl.
Poncho..It could be but I don't think thats it. Its like its filling up the front reservoir from the bottom and pushing it out the top...Glenn
Old 08-24-2005, 09:54 AM
Sounds like a bad seal. Take it back and get a new one.
Single to Dual Master Cylinder swazo Suspension - Brakes - Steering 2 10-19-2004 08:00 AM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 02:35 PM
Help! Going Nuts! Mysterious Master Cylinder delstretcho Suspension - Brakes - Steering 6 03-11-2003 05:54 AM
master cylinder differences 56don Suspension - Brakes - Steering 2 12-30-2002 08:23 PM
