master cylinder access door - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2013, 01:56 PM
jpelli's Avatar
I need to cut an access door into the fiberglass floor of my 32, do I need to do any reinforcement of the floor? If so what is the best way to do this.
Old 09-26-2013, 02:14 PM
302 Z28's Avatar
No reinforcement of the floor is needed. Just place the access door in the proper position to ease access to the MC, mark it on the floorboard and cut the hole.
Vince
Old 09-26-2013, 03:40 PM
sedanbob's Avatar
Or - consider a remote reservoir. I didn't want a door in my floor, especially after carpet, so I put a reservoir on the firewall.
Old 09-27-2013, 06:35 AM
jpelli's Avatar
Thanks to both I gave some thought to a remote fill, never saw one does it work well?
Old 09-27-2013, 08:54 AM
sedanbob's Avatar
Mine is a single reservoir that feeds both chambers in my master cylinder - some have separate reservoirs for each chamber in the master. Both can work fine. It gives you an easy way to monitor brake fluid level and top off if needed. Many of the reservoirs are translucent plastic so you can see the level without taking off the cap.
Old 09-27-2013, 11:56 AM
jpelli's Avatar
Bib, like the look of the one you have what make and where can I purchase one?
ID this master cylinder? 1937chevyII Suspension - Brakes - Steering 0 07-11-2013 12:40 PM
What should I do with the master cylinder? hogbreath73 Hotrodding Basics 4 03-17-2012 07:46 PM
Which master cylinder for me? lngliv3 Suspension - Brakes - Steering 6 09-22-2009 12:04 PM
Master cylinder 49dream Suspension - Brakes - Steering 3 06-25-2006 04:23 PM
What master cylinder? Jzarczyn Suspension - Brakes - Steering 2 12-11-2005 11:23 AM
