Master Cylinder or booster? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2011, 01:47 PM
I was on my way to the DMV and had to lock up the brake when some jerk pulled in front of me doing 10 mph, I was doing 50. My 73 Olds died on the spot. I had to push it off the road. It finally started after about 10 minutes. Since the hard braking my brake pedal is slowly sinking to the floor at stops. When I hit it hard the brakes work fine. I know the the brake sinking to the floor generally points to a master cylinder problem, but the car dying usually means that the booster is bad from what I remember.
What do you guys think? Did I blow the booster or the master cylinder?
Old 04-01-2011, 02:10 PM
LATECH's Avatar
The master is bypassing pressure, replace it.
Master cylinder and booster fordjrp Suspension - Brakes - Steering 0 09-10-2010 12:06 PM
Master cylinder without booster? Rons1stRod Suspension - Brakes - Steering 16 11-05-2007 10:06 PM
Relocate master cylinder & booster?? Longboard Suspension - Brakes - Steering 2 04-26-2006 08:47 AM
Which booster/master cylinder to get? jcarter Suspension - Brakes - Steering 1 11-17-2004 06:16 PM
62 booster/master cylinder ss62 Body - Exterior 3 07-29-2004 04:56 PM
