Master Cylinder bore size question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2011, 07:08 PM
I'm going to be replacing the single circuit master cylinder in my '62 Lark with a dual circut for safety. This coincides with a Chevy V8 engine swap. I want to go aftermarket because the old Studebakers use an odd size brake fitting. My question is regarding bore size. The stock Studebaker M/C has a 1" bore. These are manual brakes and I will be using the stock pedal setup. Does that mean I should just stay with a 1" bore and everything will work the same? Thanks.
Old 02-27-2011, 09:54 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Yes, stay with the 1" bore unless you are planning to install a booster or change the brakes at the wheels.
Andy
step bore master cylinder maninacoupe Suspension - Brakes - Steering 13 09-02-2011 10:20 PM
G-Body Master Cylinder - Bore Size? Houston54 Suspension - Brakes - Steering 3 05-01-2009 02:18 AM
Cylinder Bore Size mightycarlo10 Engine 1 01-15-2008 05:30 PM
Master Cylinder Bore Size W/Hydroboost? krehmkej Suspension - Brakes - Steering 17 03-04-2007 05:06 PM
Cylinder size for 60 over bore chevy 350 BillyBanana Engine 3 07-27-2003 10:51 AM
