I had a new 77 Ford Country Squire 460 trailer package that had hydroboost on it. You might check that MC.
I also saw an 80 Mercury Monarch (Granada) with front discs only that had hydroboost. I have been kicking myself ever since for not getting the HB from it before it hit the crusher. It had an 8.7 rear that I put into a Versailles that I got the 9" disc rear out of. The front discs went onto a 65 Falcon. Last edited by xntrik; 02-28-2007 at 11:51 AM. |
The original single system MC on my 66 GMC was the same mounting as the split-sytem (dual) MC from the 79 GMC. Have you tried bolting the Ranchero M/C up to the GM H/B? Did the Ranchero have power (vacuum) brakes previously? I guess what I'm getting at is that you may already have the correct master cylinder, and possibly the factory Ranchero brake pedal and rod may also work with the HB. Most of the brake parts are mfr'd by the same vendor (ie Bendix, Wagner) As far as I know ... the method of providing pedal effort assistance (hydroboost or vacuum) is the only difference ... and you're just substituting one for the other. 73(?) Ranchero (You didn't say what year) One of two (Stamped "1605") that fit an 86 K30 The other one (Stamped "1925") The mounting on all 3 looks the same to me ... What do the rest of you guys think ... am I nuts? Last edited by 66GMC; 02-28-2007 at 12:50 PM. |
Ford and Chevy a marriage made in Hell
First thought was just mounting the Ranchero (78) MC to the Hydroboost. Discovered that the Chevy uses a 3.4" center to center measurement, whereas the Ford is 3.2" That would mean "hogging" out the mounting holes, or rotating the HB 90 degrees and making an adaptor AND a new pushrod. So, trying to keep it simple, just figured to get a smaller diameter Chevy MC if bore is truly an issue.
In addition to the bore sizes, you will also probably want to find an MC with the same sized fittings ON THE SAME SIDE, otherwise you are looking at adapter fittings and/or re-plumbing. <sheesh> I would expect the GM hydrobosster to have Metric O-ring fittings on the hoses as well, whereas your Ranchero probably uses inverted flare fittings, right? It mighty be easier to find or order a "Ford" hydrobooster or a custom-fit kit? These guys make custom hydroboost kits. Be sure to check out the movies in the Multimedia section. |
Hydro-boost adds a lot of boost. What do you have to loose trying it? A few $5 adapters to hook it up to your brake lines? Hook it up and try it out. If there is too much pedal effort just buy a smaller GM master.
Did you look to see if a master cylinder from a 5.7 diesel with hydroboost will work?
Rick |
The 5.7 diesel is the ill-fated Oldsmobile diesel (die-sell). It was used in a wide variety of GM cars and trucks from the mid-1970s through at least 1982. All used a hydroboost brake booster.
Note that if you're mixing and matching master cylinders, you need to watch for the booster-to-MC pushrod length. |
Just so you know ... that booster-to-m/cyl rod (and associated hardware) is NOT included with either the remanufactured NAPA booster or master cylinder. All of the parts in this picture were "harvested" from an auto-wecker unit, and used with the reman NAPA components. |
Interesting picture. Thanks. I had thought that the brake pedal to HB rod was "staked" in. Obviously not the case. This unit came from a running truck. I had not planned to open it up - my manual says it cannot be worked on, replace as a unit. Obviously these pieces came out without difficulty. If possible, I would like to remove the brake pedal rod to shorten it rather than doing that with it in place.
I would think that the 1 5/16 MC is way too big for your Ranchero calipers. Check the piston size difference of the truck calipers to your car calipers and I'll bet there is a difference.
The brakes will be so touchy it will be painful to drive. I would look at a 1 1/8 or a 1" bore that will fit the HB unit. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
None of this stuff is internal to the HB unit ... they're right ... not user serviceable. The star-shaped clip, spring, and intermediate rod are in between the HB and the MC. The external snap-ring was behind the HB to firewall retaining nut, and is designed to make sure that the nut cannot possible vibrate loose and fall off. The remaining items are a pre-bent return line, hose mounting bracket, and tube clip. |
Note for the last 20 years or so, GM has broken its service manuals up and publishes a separate "Unit Repair Manual". That's where the info on rebuilding the brake boosters, steering boxes, transmissions, and axles is located. |
| Master Cylinder Failure? | Houston54 | Suspension - Brakes - Steering | 2 | 10-24-2005 02:22 PM |
| 39 Deluxe master cylinder adapter? | MM in NM | Suspension - Brakes - Steering | 4 | 09-30-2005 03:42 PM |
| Bore size question | 53LEDSLED | Engine | 5 | 05-12-2005 06:55 PM |
| 1966 Chev PU upgrade to dual master cylinder for existing brakes | Bannear | Suspension - Brakes - Steering | 7 | 10-23-2002 01:15 PM |
| Stang master cylinder | Old Crow | Suspension - Brakes - Steering | 3 | 06-10-2002 12:40 PM |
