Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Master Cylinder Bore size, what size is this?
Old 04-21-2013, 04:22 PM
bubbahotep's Avatar
bubbahotep bubbahotep is offline
Maybe my term is wrong. That's the little metal pin that the brake booster pushes into. It slides out easily of the master cylinder. It's not a piston, sorry
To change my ratio I can easily use a bracket to tilt the booster down, which brings the link arm up. Originally I had it on the top hole of my pedal (there are 2) and that's about 6:1 but only made my pedal force slightly easier.
