Master cylinder brake line questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2006, 07:20 PM
Stroker56's Avatar
I ran new brake lines on my 56 chev sedan and ended up with the driver side line coming kinda close to the #1 header pipe ,I have about an 1 1/4 inch space . Is this maybe too close given the heat in that area? Need a shield or take it off and run somewhere else?
Second question is I cannot find a master cylinder brass adapter for the brake line . Searched all day in the net and closest I can find is 1\2-20 and
9\16-18 inverted to match the 3\16 . I need a 1\4 -20 ,any idea's where to find?
Old 04-27-2006, 07:30 PM
powerrodsmike's Avatar
Wiki Edits: 161
1/4 20 is usually a thread size that a bleeder would go in, not a tube fitting. what kind of master cylinder are you using?
1 1/4 is enough space from the header.
mikey
BE different....ACT normal.
Old 04-27-2006, 07:56 PM
Stroker56's Avatar
It is brand new duel reservoir and was told it was for a 68 camaro with non power drum \drum . It is a bolt up to the firewall on the 56 It's just the ports that screwed me up The plugs that are in the ports now have the 9\16-18 and 1\4-20 stamped on them .I can get an adapter for the 9\16-18 to 3\16
but not a 1\4-20 to 3\16 for the invertered flare fitting
Old 04-27-2006, 08:01 PM
Wiki Edits: 161
you need to check the size of those outlets. It is not a 1/4 20. The threaded holes in that mc are the same size as common sae fasteners. Go get a 3/8 -24, a 7/16- 20 , a 1/2 20, a 9/16 18 bolt(s) and see which one threads in to the master cylinder. That is the size you need. speedway motors in lincoln nebraska has a good selection of those.
Hope this helps, mikey
Old 04-27-2006, 08:20 PM
Stroker56's Avatar
Mikey
You are right the 1\2-20 fits the front and a 9\16-18 fits the rear.
I have been looking for the wrong size .I looked at the plug in the smaller port , removed it for a better look and with my glasses on this time . And what I thought was a 4 is actually is a 2 so it is 1\2 not 1\4 . No wonder the guy at Napa was looking at me wondering what planet I was from.
Thanks for straightening that out for me.
Old 04-27-2006, 08:40 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
NAPA should have it now that your on the right track.
1950 chevy master brake cylinder chevyfordguy Suspension - Brakes - Steering 2 08-12-2011 09:48 AM
Brake Line - 3 way fitting, one way only? BIGSKY Suspension - Brakes - Steering 2 11-17-2005 02:30 PM
32 ford manual/drum brake cylinder? help! zuppamon Suspension - Brakes - Steering 2 10-27-2004 05:30 PM
Single to Dual Master Cylinder swazo Suspension - Brakes - Steering 2 10-19-2004 08:00 AM
Stang master cylinder Old Crow Suspension - Brakes - Steering 3 06-10-2002 12:40 PM
