Master cylinder and combination valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2009, 10:34 PM
Hey Guys,
I just mounted my new master cylinder on my firewall. I went from a power brake setup to a manual. Now my combination valve is just a tad higher then the master cylinder. It's actually just about even but my lines will be higher. Will this hurt? Thanks.
Thom
Old 03-20-2009, 09:51 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
If it is the high spot in the system, any air in the lines will likely end up at that point and it could be hard to get it all out.
Andy
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Combination Valve advice required old pop General Rodding Tech 5 08-31-2006 05:16 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
master cylinder and proportioning valve? curtisstarlight Suspension - Brakes - Steering 3 03-18-2003 09:12 AM
Combination valve for disk/drum setup TurboStude Suspension - Brakes - Steering 1 04-01-2002 06:39 AM
