master cylinder cover?
Hey does anybody know where to get a master cylinder cover for a gm style master cylinder that allows you to hook up a remote fill to ? I want to make a remote fill for my pickup but dont want to buy a kit if i dont have to
thats my problem looking for it and cant find any of them that are cheap. lol. Yes i have it mounted under the floor and it is not easy to fill when its under there
how about modifying the old one??a couple of fittings some pipe or tube,,and a reservoir,,have vent tube higher than reservoir,, and you should be fine,,end of vent tube a small piece of pipe ,,end braised closed,,and 2 small holes drilled at top side..
use ether steel or rubber brake lines..still gona cost around $30.00 |
I was thinking about that but the way the gm m/c is the fittings would be hard to fit in and i would assume you dont want air in the m/c so you have to get a tight fit
Master Cyl Cover
Hey 49ford/p/u, I have seen the whole kit including master cyl., but not just the cover. If you locate one please post the source. I'm also interested in the rack & pinion for straight axles. I'm looking for feedback from someone who has actually installed and driven the no limit eng. unit. I'm mostly concerned with steering column vibration. Please give us some feedback on yours when you can drive it. Thanks, OLNOLAN
| Master cylinder without booster? | Rons1stRod | Suspension - Brakes - Steering | 16 | 11-05-2007 09:06 PM |
| using only the master cylinder and takin out the break booster | Arillious | Suspension - Brakes - Steering | 12 | 08-14-2007 11:02 AM |
| HELP ASAP - 77 T/A Master Cylinder and Prop. Valve Question | Torx | Suspension - Brakes - Steering | 1 | 06-26-2006 01:52 AM |
| 39 Deluxe master cylinder adapter? | MM in NM | Suspension - Brakes - Steering | 4 | 09-30-2005 03:42 PM |
| master cylinder and proportioning valve? | curtisstarlight | Suspension - Brakes - Steering | 3 | 03-18-2003 09:12 AM |
