-   -   master cylinder for drum/drum or disc/drum (http://www.hotrodders.com/forum/master-cylinder-drum-drum-disc-drum-220974.html)
GMR 06-25-2012 12:10 PM
I have a single reservoir manual drum/drum M/C with 7/8 bore now. Want to convert to dual reservoir M/C and maybe manual disc/drum in the future. I found a dual reservoir M/C with a 7/8 bore and 1.10 stroke. Will this M/C support a manual disc/drum system?
painted jester 06-29-2012 12:45 PM
It may there are many variables like the fulcrum point of the actuating rod on the pedal to the mc and the pressure ratio to your foot pressure and the size of your calipers.
Cape Cod Bob 06-29-2012 07:42 PM
I found MP Brakes a great source of info for different configuration. Explore their website and order theier catalog.
http://www.mpbrakes.com/:welcome:
10Tonhammer 07-20-2012 10:58 AM
I m curious as well because I'm in a similar situation. I do know that a drum/ drum mc will not work for disc/drum setup as it doesn't move enough fluid for calipers. I would like to know if a disc/drum mc would work for drum/drum setup.
Kris.
swvalcon 07-23-2012 06:51 AM
I had a 75 corvette power master on my vega drag car. At frist we had it set up with manual drum-drum brakes and it worked ok. Then we went to mustang two front disks and it works perfect, No pulling,stops straight,easy pedal pressure. Rears are 11" chev 1/2 ton drums.
enjenjo 07-23-2012 09:11 PM
The only difference between a drum/drum, a disc.drum, and a disc/disc master cylinder is the residual valves. Drum brakes have them built in, and disc brakes don't. If you want to run drums with a disc brake master, install external residual valves.
An easy way to check the master for residual valves, try to insert a toothpick in the fitting on the master cylinder.If it goes right in the cylinder bore, there is no residual valve. If it hits something about 1.4" in, it has a residual valve.
If you have a firewall mounted master cylinder, you might get by with a disc master cylinder, with no residual valves, and drum brakes
