master cylinder for drum/drum or disc/drum - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2012, 12:10 PM
GMR GMR is offline
I have a single reservoir manual drum/drum M/C with 7/8 bore now. Want to convert to dual reservoir M/C and maybe manual disc/drum in the future. I found a dual reservoir M/C with a 7/8 bore and 1.10 stroke. Will this M/C support a manual disc/drum system?
Old 06-29-2012, 12:45 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
It may there are many variables like the fulcrum point of the actuating rod on the pedal to the mc and the pressure ratio to your foot pressure and the size of your calipers.
Old 06-29-2012, 07:42 PM
Cape Cod Bob's Avatar
I found MP Brakes a great source of info for different configuration. Explore their website and order theier catalog.
http://www.mpbrakes.com/
Old 07-20-2012, 10:58 AM
I m curious as well because I'm in a similar situation. I do know that a drum/ drum mc will not work for disc/drum setup as it doesn't move enough fluid for calipers. I would like to know if a disc/drum mc would work for drum/drum setup.
Kris.
Old 07-23-2012, 06:51 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I had a 75 corvette power master on my vega drag car. At frist we had it set up with manual drum-drum brakes and it worked ok. Then we went to mustang two front disks and it works perfect, No pulling,stops straight,easy pedal pressure. Rears are 11" chev 1/2 ton drums.
Old 07-23-2012, 09:11 PM
The only difference between a drum/drum, a disc.drum, and a disc/disc master cylinder is the residual valves. Drum brakes have them built in, and disc brakes don't. If you want to run drums with a disc brake master, install external residual valves.
An easy way to check the master for residual valves, try to insert a toothpick in the fitting on the master cylinder.If it goes right in the cylinder bore, there is no residual valve. If it hits something about 1.4" in, it has a residual valve.
If you have a firewall mounted master cylinder, you might get by with a disc master cylinder, with no residual valves, and drum brakes
Disc/drum Master Cylinder wolfeman Suspension - Brakes - Steering 6 06-11-2009 05:38 PM
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
Master cylinder disc/drum combo DirtDoctor Suspension - Brakes - Steering 5 12-28-2005 09:55 AM
Master cylinder: Disc/drum vs. drum/drum wp442 Suspension - Brakes - Steering 4 09-28-2004 02:46 PM
Dual master cylinder for drum/disc brakes wiretwister Suspension - Brakes - Steering 4 02-16-2003 08:56 AM
