Master Cylinder Gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2006, 08:18 PM
WarChilde's Avatar
Last journal entry: 1978 Nova
Hello, I am having a problem with my master cylinder gasket becoming warped. My setup is a '78 Nova, stock front with rear '79 T/A. Master cylinder and proportioning valve are of the '79 T/A. Using DOT3 fluid.
Just started recently, never had this problem before.
Old 08-11-2006, 10:16 AM
How many gaskets have you warped ??
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 02:35 PM
Help! Going Nuts! Mysterious Master Cylinder delstretcho Suspension - Brakes - Steering 6 03-11-2003 05:54 AM
