Master cylinder to header distance and heat - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2013, 01:54 PM
bonuts's Avatar
Got Ouzo for touzo
Just trying to plumb my clutch set up into my s-10. Running to clearance issues again (of course) my master cylinder location is only going to give me around a 1.5" between it and the header.
The headers are coated to try get some heat out but will this be enough room? I'm going to run a hydraulic throw out because of my clearance issues under the truck
bonuts
Old 06-25-2013, 02:53 PM
Banned
you should be fine but make sure you use something like this.
Wilwood High Temperature Brake Fluid
Old 06-25-2013, 03:40 PM
bonuts's Avatar
Got Ouzo for touzo
Ok sounds good. Thought this was gonna be the big snag I didn't need
Old 06-25-2013, 06:53 PM
techinspector1's Avatar
Wiki Edits: 326
I have fixed problems like this for little cost in the past by using scraps of thin aluminum fastened to prevent heat from reaching the part that I wanted to protect. Reallllllllly bulletproof is two pieces sandwiched together and separated by a few flat washers to create a dead air space between the two pieces of aluminum. Scroll down through this collage of heat deflectors and see if any of it strikes a fancy for you.
https://www.google.com/search?hl=en&...er%3B225%3B168
Old 06-25-2013, 08:15 PM
bonuts's Avatar
Got Ouzo for touzo
Not sure why I didn't even think heat shield like those. Was thinking a wrap but I can easily build one if them.
bonuts
Header heat help Fairlane351 Engine 4 05-28-2013 07:59 PM
master cylinder heat shield metalstorm Projects/Builds/My Ride 0 05-27-2013 01:38 PM
Header Heat problem Fairlane351 Engine 20 10-25-2010 05:51 AM
excessive header heat dlr2873 Engine 4 09-01-2007 11:17 AM
