Master Cylinder Help Needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2008, 06:22 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I am building a 1989 S10 drag race project. The truck right now has the factory master cylinder and brake booster which I would like to get rid of to make more room on the firewall and to clean things up. I have been looking at aftermarket manual master cylinders. What is so different from the master cylinders you use with power brakes and the older manual type? Can you take the master cylinder off the booster and use it as a manual type?
Thanks
Old 04-28-2008, 06:28 PM
Wiki Edits: 31
no.. you can't use a power M/C for non power brakes, the bore is too big. also the pedal ratios are different. but really, it's a drag truck and your gonna want to stop it easilly.. keep the booster
Old 04-28-2008, 07:30 PM
keep the power brakes, ypu wanna get rid of anything get rid of the heater and all that goes with it and then just close up the holes in the firewall thats what i did with my S10
Old 04-28-2008, 09:13 PM
Just go to the j/y and pick up the pedal assembly from a manual brake S10. Then get a rebuilt manual brake S10 master cylinder from the parts store (and the rear wheel cylinders if you are keeping the stock rear end).
Old 04-28-2008, 10:23 PM
RODDER18's Avatar
Quick tip...The bigger the master cylinder is, the more fluid you will have but you wll have less pressure at the caliper. If you do make the swap you may want to install an adjustable proportioning valve. Because of the added weight to the front and knowing how light the rear of the S-10 is you may want to be able to adjust the brakes manually. Another option to clean up the firewall would be to install a frame mounted master or under dash style both would work. If you do install a frame style you will also need residual valves front and rear.
How much volume needed in master cylinder. jimcar-9 Suspension - Brakes - Steering 7 09-21-2007 12:07 PM
Master Cylinder Help Needed glg97 Suspension - Brakes - Steering 2 11-06-2005 08:20 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 04:42 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 03:35 PM
Stang master cylinder Old Crow Suspension - Brakes - Steering 3 06-10-2002 01:40 PM
