Master Cylinder Help Needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2005, 06:54 PM
glg97's Avatar
Master Cylinder Help Needed (under dash pedal and master cylinder)
I'm looking for a reversed master cylinder brake pedal set up with a dual master cylinder non power. Kugel Components has one , but there has to be more than 1 manufacturer out there. Building a 27 Ford roadster and space is at a premium. The frame mounted kit I bought for Speedway did not cut it and would not allow me enough room for the Ididit column and swivel mounting collar. If any one knows of a source to there hot rod land please let me know.
THANKS
G
Old 11-02-2005, 07:17 PM
ragenrat638's Avatar
CRASH TEST DUMMY !!!!!!
welcome my hotrod brother....
mp brakes is the mother of all brake parts....
http://search.hp.netscape.com/hp/boo...pbrakes.com%2F
Old 11-06-2005, 07:20 PM
techinspector1's Avatar
Wiki Edits: 326
THANKS
G
Why would you not want to use Kugel's, I used it on my last T project with a Midland-Ross booster (very heavy car with 2" x 6" frame rails and 429/C6, 117" wheelbase) and 'Vette master cylinder and it worked slick. I made a loop of 1 1/2" x 1 1/2" square steel tubing that came off the frame rails at the cowl and up to the top inside of the cowl to mount everything to. I also ran 2 diagonals, 1" x 1" back to just before the front of the doors. Very solid.
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 02:35 PM
Master cylinder swap needed Paul Gaudette Suspension - Brakes - Steering 1 05-26-2003 11:31 AM
Help! Going Nuts! Mysterious Master Cylinder delstretcho Suspension - Brakes - Steering 6 03-11-2003 05:54 AM
